Zum Hauptinhalt wechseln
Shark ION Robot 750 Outer Shell Replacement
Was du brauchst
  1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: Schritt 1, Bild 1 von 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: Schritt 1, Bild 2 von 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: Schritt 1, Bild 3 von 3
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Outer Shell Replacement: Schritt 2, Bild 1 von 2 Shark ION Robot 750 Outer Shell Replacement: Schritt 2, Bild 2 von 2
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Outer Shell Replacement: Schritt 3, Bild 1 von 2 Shark ION Robot 750 Outer Shell Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Outer Shell Replacement: Schritt 4, Bild 1 von 2 Shark ION Robot 750 Outer Shell Replacement: Schritt 4, Bild 2 von 2
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Outer Shell Replacement: Schritt 5, Bild 1 von 3 Shark ION Robot 750 Outer Shell Replacement: Schritt 5, Bild 2 von 3 Shark ION Robot 750 Outer Shell Replacement: Schritt 5, Bild 3 von 3
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Outer Shell Replacement: Schritt 6, Bild 1 von 1
    • Lift the outer shell to expose the Shark’s interior.
Abschluss
Youness Elfath
183 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 107
