Zum Hauptinhalt wechseln
Shark ION Robot R75 Caster Wheel Replacement
Was du brauchst
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: Schritt 1, Bild 1 von 1
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: Schritt 2, Bild 1 von 3 Shark ION Robot R75 Caster Wheel Replacement: Schritt 2, Bild 2 von 3 Shark ION Robot R75 Caster Wheel Replacement: Schritt 2, Bild 3 von 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: Schritt 3, Bild 1 von 3 Shark ION Robot R75 Caster Wheel Replacement: Schritt 3, Bild 2 von 3 Shark ION Robot R75 Caster Wheel Replacement: Schritt 3, Bild 3 von 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
Abschluss
Ein Kommentar
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 75
Insgesamt: 4,816
