Zum Hauptinhalt wechseln
Shark ION Robot R75 Main Brush Replacement
  1. Shark ION Robot R75 Main Brush Replacement, Main Brush: Schritt 1, Bild 1 von 1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  2. Shark ION Robot R75 Main Brush Replacement: Schritt 2, Bild 1 von 1
    • Pull the main brush slightly to the right to remove it from the compartment.
  3. Shark ION Robot R75 Main Brush Replacement: Schritt 3, Bild 1 von 2 Shark ION Robot R75 Main Brush Replacement: Schritt 3, Bild 2 von 2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
Abschluss
Ein Kommentar
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 50
Insgesamt: 2,660
