Zum Hauptinhalt wechseln
Shark ION Robot R75 Side Brush Replacement
Was du brauchst
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: Schritt 1, Bild 1 von 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: Schritt 1, Bild 2 von 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: Schritt 1, Bild 3 von 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
Abschluss
2 Kommentare
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - Antwort
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 39
Letzte 30 Tage: 146
Insgesamt: 6,256
