Zum Hauptinhalt wechseln
Shark ION Robot S87 Bumper Replacement
Was du brauchst
  1. Shark ION Robot S87 Bumper Replacement, Bumper: Schritt 1, Bild 1 von 1
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: Schritt 2, Bild 1 von 3 Shark ION Robot S87 Bumper Replacement: Schritt 2, Bild 2 von 3 Shark ION Robot S87 Bumper Replacement: Schritt 2, Bild 3 von 3
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: Schritt 3, Bild 1 von 1
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Adeel Ahmad
256 Reputation
2 Anleitungen geschrieben
York University, Team S1-G7, Woodhouse Winter 2020 Mitglied von York University, Team S1-G7, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G7
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can I buy a new bumper?
Lacy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 147
Insgesamt: 11,770
