Einleitung
If your Shark ION Robot S87 has problems getting around, then you may need some new drive wheels. This guide will show you how to replace the wheels, and get it cleaning again.
Was du brauchst
Remove three 13mm screws using a T15 Torx screwdriver.
Remove one 15mm screw using a Phillips #1 screwdriver.
Remove one final 15mm Phillips #1 screw.
Carefully lift the wheel assembly out of the housing, making sure not to damage its connecting wire.
Disconnect the wire carefully from the wheel assembly by pinching and pulling away from it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
