Zum Hauptinhalt wechseln
Shark ION Robot S87 Drive Wheel Replacement
Was du brauchst
  1. Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: Schritt 1, Bild 1 von 2 Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: Schritt 1, Bild 2 von 2
    • Make sure device is turned off before attempting this replacement.
    • Remove three 13mm screws using a T15 Torx screwdriver.
    • Remove one 15mm screw using a Phillips #1 screwdriver.
    • Remove one final 15mm Phillips #1 screw.
  2. Shark ION Robot S87 Drive Wheel Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift the wheel assembly out of the housing, making sure not to damage its connecting wire.
  3. Shark ION Robot S87 Drive Wheel Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the wire carefully from the wheel assembly by pinching and pulling away from it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Trevor Davies
297 Reputation
2 Anleitungen geschrieben
York University, Team S1-G7, Woodhouse Winter 2020 Mitglied von York University, Team S1-G7, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G7
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
DovieAndiSeTova - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 36
Insgesamt: 1,765
