Einleitung
The lithium-ion power pack in the Shark IONFlex 2X is easily replaced by the user with no tools required. The Shark IONFlex 2X comes with two power packs that can be used in the unit and recharged in a separate charging unit. One battery can be used while the other is charging for convenience.
Squeeze the lever located at the bottom of the lithium power pack labeled “Battery Release”.
While squeezing the lever at the bottom of the power pack, pull out the battery pack to remove the battery.
Eine weitere Person hat diese Anleitung absolviert.
