Zum Hauptinhalt wechseln
Shark IQ AV993 Bumper Replacement
Was du brauchst
  1. Shark IQ AV993 Bumper Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Bumper Replacement: Schritt 2, Bild 1 von 1
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Bumper Replacement, Bumper: Schritt 3, Bild 1 von 2 Shark IQ AV993 Bumper Replacement, Bumper: Schritt 3, Bild 2 von 2
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Bumper Replacement: Schritt 4, Bild 1 von 1
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Bumper Replacement: Schritt 5, Bild 1 von 1
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
Abschluss
Kyle Rhines
558 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Mitglied von UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 791
