Einleitung
Dirty filters will cause the vacuum to work less efficiently. Make sure to replace your filter on a regular basis.
Lift the latches on both sides of the vacuum to release the dust canister.
Tilt the dust canister forward to release it from its position.
Carefully lift away the dust canister and set it aside.
Remove the upper filter by lifting upwards on it.
Now that the lower filter is exposed, remove it by pulling it upwards.
4 weitere Personen haben diese Anleitung absolviert.
