Zum Hauptinhalt wechseln
Einleitung
When the roller belt has snapped or your vacuum's roller brush is not spinning, you should look into replacing your roller belt.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the device over to reveal the bottom of the motorized brush head.
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Slide the latch next to the panel upwards into the unlocked position. Slide the latch next to the panel upwards into the unlocked position.
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Slide the panel to the right to reveal the battery.
    • Slide the panel to the right to reveal the battery.
  4. Pull the battery from the vacuum. Pull the battery from the vacuum.
    • Pull the battery from the vacuum.
  5. Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart. Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
  6. Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum. Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it. Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
    • Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum.
    • Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
  7. Remove the final 25.4 mm Phillips #1 screw inside the battery compartment.
    • Remove the final 25.4 mm Phillips #1 screw inside the battery compartment.
  8. Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum. Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum. Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum.
    • Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum.
  9. Remove the 12.2 mm Phillips #1 screws holding the motor in place and remove the motor by pulling directly upwards. Remove the 12.2 mm Phillips #1 screws holding the motor in place and remove the motor by pulling directly upwards. Remove the 12.2 mm Phillips #1 screws holding the motor in place and remove the motor by pulling directly upwards.
    • Remove the 12.2 mm Phillips #1 screws holding the motor in place and remove the motor by pulling directly upwards.
  10. Remove the belt by sliding it off the end of the motor. Remove the belt by sliding it off the end of the motor.
    • Remove the belt by sliding it off the end of the motor.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Zachary Liu
523 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G5, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Mitglieder
Where can I purchase the belt. It is a “Pioneer Rubber Belt 148 2m”.
Please contact me.
Thank you.
itsagas03@hotmail.com
itsagas03 - Antwort
I got the belt from http://shop.polybelt.com/ It is item B148-2M-04BNG . You have to buy 3 to get to $9.99 and then they tack on another $10 for shipping, but this was the only place I could find them. Replaced it and it seems to be working ok.
rmagnus - Antwort
The brush stops tolling after a few seconds. How do I trouble shoot this?
Peter Fogler - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 6
Letzte 7 Tage: 13
Letzte 30 Tage: 73
Insgesamt: 1,717
