Zum Hauptinhalt wechseln
Einleitung
If your roller brush is not working even after removing surrounding debris, it is time to replace the roller brush.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the black rubber band from the roller brush In most models there will be a plastic cover over the rubber band. You will use the quarter to twist the latch and take off the cover
    • Remove the black rubber band from the roller brush
    • In most models there will be a plastic cover over the rubber band. You will use the quarter to twist the latch and take off the cover
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Use the bristles to pull the end of the brush that was connected to the belt away from the vacuum. Use the bristles to pull the end of the brush that was connected to the belt away from the vacuum. Use the bristles to pull the end of the brush that was connected to the belt away from the vacuum.
    • Use the bristles to pull the end of the brush that was connected to the belt away from the vacuum.
  4. Slide the roller belt off of the roller brush and pull the roller away from the motorized brush. Slide the roller belt off of the roller brush and pull the roller away from the motorized brush. Slide the roller belt off of the roller brush and pull the roller away from the motorized brush.
    • Slide the roller belt off of the roller brush and pull the roller away from the motorized brush.
Abschluss
Zachary Liu
508 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G5, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Mitglieder
but where can I buy the brush for model SV1106?
ellenmccarthycalif - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 33
Insgesamt: 740
