Einleitung
When cleaning the HEPA filter does not improve your vacuum's suction, it is time to replace it.
On the front of the vacuum, locate the latch on the bottom of the front vent.
3 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
the taking out worked great but putting the new one back in is impossible.......will not fit i will not buy a new vac because of this........
this is the second filter that i have purchased and it is the same...does not fit properly i could use a hammer to it?????
I can’t get the Hepa filter to come out, the front comes out easily, but the actual filter behind it will not. How do I remove it?
@lynndavidson lay the machine on its back, get someone without fingernails to grab both sides of HEPA and pull STRAIGHT UP. It is pretty tight. You might be able to pop a side up by prying with a flat screw driver or small putty knife? Just don’t chip the housing.
