Zum Hauptinhalt wechseln
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: Schritt 1, Bild 1 von 1
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 2, Bild 1 von 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 2, Bild 2 von 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 2, Bild 3 von 3
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 3, Bild 1 von 2 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 3, Bild 2 von 2
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 4, Bild 1 von 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 4, Bild 2 von 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 4, Bild 3 von 3
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 5, Bild 1 von 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 5, Bild 2 von 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: Schritt 5, Bild 3 von 3
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S15-G2, Livingston Fall 2017 Mitglied von Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 4,930
