Einleitung
Replacing the roller brush motor can help improve the functionality of the vacuum cleaner. The roller brush belt needs to be removed first in order to replace the motor.
Was du brauchst
Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
Insert the metal spudger between the inside side of the wheel and the plastic body.
Push the metal spudger away from you to pop the wheels out.
Repeat the step to remove the other wheel on the other side.
Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
Lift the roller brush slightly upwards using your hand.
Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
Remove the roller brush belt with your hands by sliding it of the end of the motor.
Remove the roller brush from the plastic frame using your hands by lifting it away.
Lift the roller brush motor up and away from its half-cylindrical holder with your hand.
Locate the two connectors coming out of the roller brush motor.
Pinch and pull the blue plastic insulation down the wire and away from the motor until the metal connectors are fully exposed.
Locate the protrusion near the connection between the metal and wire.
Push down on the protrusion with your finger and push the metal connector away from the motor with the metal spudger.
Continue to push on the connector away from the motor with the metal spudger until it is disconnected completely.
Repeat the steps 12-14 for the other wire.
Take the motor out and away from the motorized floor brush compartment by hand.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Well this looks really handy to read! Where can I get a replacement motor? Any helpful links!? :)
Yes! Where do I buy the motor?
Where do you find the motor? Any part numbers??
Where to find a motor? Shark has work to do!!!
