Zum Hauptinhalt wechseln
Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement
Was du brauchst
  1. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: Schritt 1, Bild 1 von 2 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: Schritt 1, Bild 2 von 2
    • Make sure to turn off the vacuum and unplug it from the outlet.
  2. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: Schritt 2, Bild 1 von 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: Schritt 2, Bild 2 von 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: Schritt 2, Bild 3 von 3
    • Push down on the bottom of the vacuum so it can dangle.
    • Using a flathead screwdriver to turn the lock counterclockwise, then open the cover to access the brush roll.
  3. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: Schritt 3, Bild 1 von 1
    • Clear out any debris and close up the bottom using the previous steps.
    • Unfortunately, the new technology implemented in the self-cleaning brush roll prevents it from being detachable. You have a guaranteed 5-year warranty from Shark. Contact them using this link.
Abschluss
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
CSU Los Angeles, Team 11-5, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-5, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G5
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
The brush roller and placement of it is filthy with dog hair and dirt needs to be scraped out. There must be a way to remove it to clean without having to send it to the manufacturer
Nana - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 25
Letzte 30 Tage: 147
Insgesamt: 4,168
