Einleitung
Brush heads are prone to collecting debris and unwanted material. This guide will show you how to properly access and remove the brush head.
Was du brauchst
Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
Lay the vacuum on its side.
Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
Repeat this for the other wheel.
Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
Lift up the brush head from the plastic housing, slight force may be needed.
Remove the band from the brush head.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Taking the thing apart is one thing, but identifying the part numbers (motor, belt, brush) to replace the old worn stuff is another. I haven't found the part numbers for these things (or the exploded parts view for the vacuum itself or either of the two power heads. Does anyone know whereabouts these things can be found?
