Zum Hauptinhalt wechseln
Shark Navigator Lightweight Upright Dust Cup Replacement
  1. Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: Schritt 1, Bild 1 von 2 Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: Schritt 1, Bild 2 von 2
    • Press down on the black, rubber ballish button located on the top of the vacuum.
    • Pull back simultaneous on the plastic handle and remove the dust container.
  2. Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 2, Bild 1 von 3 Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 2, Bild 2 von 3 Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 2, Bild 3 von 3
    • Press the plastic tab in, located on the front of the dust container.
    • Pull up simultaneously on the plastic handle.
  3. Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 3, Bild 1 von 2 Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 3, Bild 2 von 2
    • Remove the dust cup from the inside of the dust container.
  4. Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 4, Bild 1 von 3 Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 4, Bild 2 von 3 Shark Navigator Lightweight Upright Dust Cup Replacement: Schritt 4, Bild 3 von 3
    • Push in the red tab located on the side of the dust cup.
    • Open the dust cup simultaneously with the cone-half pointing downwards.
    • Separate the two halves.
Abschluss
Kahye Yu
446 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S4-G6, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 24
Letzte 30 Tage: 87
Insgesamt: 3,312
