Zum Hauptinhalt wechseln
Shark Navigator Lightweight Upright Head Shell Replacement
Was du brauchst
  1. Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: Schritt 1, Bild 1 von 2 Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: Schritt 1, Bild 2 von 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 2, Bild 1 von 2 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 2, Bild 2 von 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 3, Bild 1 von 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 4, Bild 1 von 3 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 4, Bild 2 von 3 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 4, Bild 3 von 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 5, Bild 1 von 2 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 6, Bild 1 von 2 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 7, Bild 1 von 2 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 8, Bild 1 von 3 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 8, Bild 2 von 3 Shark Navigator Lightweight Upright Head Shell Replacement: Schritt 8, Bild 3 von 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
Abschluss
Suzie
527 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S4-G6, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
I have been doing exactly what the steps require but have not been able to remove the cover. Each time I am able to release one side the other side snaps back and the fixit tools fall out or fall inside.
Please give me any suggestions to accomplish removing the cover. Thank you.
Diane Snelling - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 945
