Zum Hauptinhalt wechseln
Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: Schritt 1, Bild 1 von 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: Schritt 1, Bild 2 von 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: Schritt 1, Bild 3 von 3
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: Schritt 2, Bild 1 von 2 Shark Navigator Lightweight Upright Hose Replacement: Schritt 2, Bild 2 von 2
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: Schritt 3, Bild 1 von 3 Shark Navigator Lightweight Upright Hose Replacement: Schritt 3, Bild 2 von 3 Shark Navigator Lightweight Upright Hose Replacement: Schritt 3, Bild 3 von 3
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kahye Yu
446 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S4-G6, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
Where can I find a replacement hose?
Vance Payne - Antwort
How to replace the bottom pick up hose.
rgg20319 - Antwort
How to fix the bottom hose?
rgg20319 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 70
Insgesamt: 3,340
