Einleitung
A damaged hose will not allow the vacuum to work properly. This guide will show how to detach the hose from the vacuum.
Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
Pull down on the tube while maintaining pressure on the tab.
Separate the upper connection of the tube from the housing, releasing the hose.
Locate the lower attachment of the hose found in the bottom left corner.
Pull the hose down towards the floor, releasing the hose from the hose guide.
Pull up on the hose pipe located on the right side of the vacuum firmly.
Lift the hose pipe upwards and all the way through the plastic guide ring.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
