Zum Hauptinhalt wechseln
Shark Navigator Lightweight Upright Motor Replacement
Was du brauchst
  1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: Schritt 1, Bild 1 von 2 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: Schritt 1, Bild 2 von 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motor Replacement: Schritt 2, Bild 1 von 2 Shark Navigator Lightweight Upright Motor Replacement: Schritt 2, Bild 2 von 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motor Replacement: Schritt 3, Bild 1 von 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motor Replacement: Schritt 4, Bild 1 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 4, Bild 2 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 4, Bild 3 von 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motor Replacement: Schritt 5, Bild 1 von 2 Shark Navigator Lightweight Upright Motor Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motor Replacement: Schritt 6, Bild 1 von 2 Shark Navigator Lightweight Upright Motor Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motor Replacement: Schritt 7, Bild 1 von 2 Shark Navigator Lightweight Upright Motor Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motor Replacement: Schritt 8, Bild 1 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 8, Bild 2 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 8, Bild 3 von 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motor Replacement, Motor: Schritt 9, Bild 1 von 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motor Replacement: Schritt 10, Bild 1 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 10, Bild 2 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 10, Bild 3 von 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motor Replacement: Schritt 11, Bild 1 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 11, Bild 2 von 3 Shark Navigator Lightweight Upright Motor Replacement: Schritt 11, Bild 3 von 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motor Replacement: Schritt 12, Bild 1 von 2 Shark Navigator Lightweight Upright Motor Replacement: Schritt 12, Bild 2 von 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Suzie
527 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S4-G6, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Where does one buy the replacement motor?
Michael De La Rosa - Antwort
Where can I get spares??
ck
Clive Kingscote - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 56
Insgesamt: 9,532
