Was du brauchst
Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
There is one screw at the edge of the circuit board. Unscrew the circuit board before attempting to take it out.
Take out the circuit board and replace with a new one. It may be better to allow a professional to re-wire the circuit board to the vacuum.
3 weitere Personen haben diese Anleitung absolviert.
8Leitfaden Kommentare
Hi ..well done with the instructions.However I do have a Shark rotator vacuum NV501 .Unfortunately the motor on the brush is not working ,so I assume the motor is burnt.My request where could I find a replacement of the motor.I have searched a lot sites online but could not find a place to rebuild nor stock the same motor.Any help would be appreciated.Thank you.....To forward any information please do so on my email jacob.brown at hotmail.com thank you....
When I had mine apart, two black rectangle magnet fell out, I can't figure out where the came from.
I had the same problem with the magnets - where do they go>
