Einleitung
Step by step guide on replacing the internal brush rotation belt. After removing a few screws, you can access the internal components of the motorized brush. After removing the belt, you should exercise care in handling the belt.
Was du brauchst
Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
Angehängte Dokumente
Ein Kommentar
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
