Zum Hauptinhalt wechseln
Shark Professional Steam Pocket Mop Open Mop Body Replacement
Was du brauchst
  1. Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: Schritt 1, Bild 1 von 2 Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: Schritt 1, Bild 2 von 2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 2, Bild 1 von 3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 2, Bild 2 von 3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 3, Bild 1 von 2 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 3, Bild 2 von 2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 4, Bild 1 von 3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 4, Bild 2 von 3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 4, Bild 3 von 3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 5, Bild 1 von 3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 5, Bild 2 von 3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 5, Bild 3 von 3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 6, Bild 1 von 1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Open Mop Body: Schritt 7, Bild 1 von 1
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  8. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  9. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 9, Bild 1 von 1
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  10. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 10, Bild 1 von 1
    • Pop off the dark grey plastic trim cover.
  11. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: Schritt 11, Bild 1 von 1
    • Pop open the white plastic mop body by pulling apart from the front and back side.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brett Wilson
992 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S15-G1, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
good afternoon, i need the water pump for that shark steamer. my model is S3601A.
Thank you.
Eduardo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 5,470
