Einleitung
This guide will start with opening the front panel. This will expose the control panel and more screws for further disassembly. Before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug both the mop and empty the water tank for your safety.
Was du brauchst
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
Remove the plastic cap.
Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
Remove steam control button cover with a metal spudger.
Remove the two 12.0 mm Phillips head #2 screws underneath.
Remove the plastic rim with clear plastic cover.
Remove the Shark logo decal on the front of body using a metal spudger.
Pull out the plastic cover to remove.
Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
Ein Kommentar
Here is a video to help with dismantling if you'd like to see the possible original guide first posted on YouTube by George Robles September 16, 2015 years before.
No one knew or posted before me because I looked everywhere and why I created the video.
But I am curious where you got your information from if it was not my video.
