Zum Hauptinhalt wechseln
Shark Professional Steam Pocket Mop Water Tank Cap Replacement
  1. Shark Professional Steam Pocket Mop Water Tank Cap Replacement, Water Tank Cap: Schritt 1, Bild 1 von 2 Shark Professional Steam Pocket Mop Water Tank Cap Replacement, Water Tank Cap: Schritt 1, Bild 2 von 2
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that the water in the water tank cools to room temperature before proceeding.
  2. Shark Professional Steam Pocket Mop Water Tank Cap Replacement: Schritt 2, Bild 1 von 3 Shark Professional Steam Pocket Mop Water Tank Cap Replacement: Schritt 2, Bild 2 von 3 Shark Professional Steam Pocket Mop Water Tank Cap Replacement: Schritt 2, Bild 3 von 3
    • Remove the water tank cap from the water tank reservoir.
    • Turn the cap towards the upward position.
    • Rotate counter-clockwise until it loosens.
    • When reassembling, align the grooves of new water tank cap with the opening of water tank reservoir and then push in.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Wicke
237 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team S1-G3, Rose Fall 2018 Mitglied von UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
4 Mitglieder
10 Anleitungen geschrieben
13 Kommentare
Need a water cap for S3901 N3 11 Shark steam mop. They said they discontinued and I have ordered two online and neither will work. And I really going to have to buy a new one?
shannon poole - Antwort
Same here did you come across one
carl yardley -
Did you find any place that sold these caps? I’m in the same boat need a new water cap.
Rick -
hola a mi trapeador shark lift away no le sale vapor y es nuevo tendra algun defecto?
Eveliza Higuera - Antwort
Any updates on getting this part
bryn.rees - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 64
Insgesamt: 9,708
