Zum Hauptinhalt wechseln
Shark Rocket HV301 Rotary Belt Replacement
Was du brauchst
  1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: Schritt 1, Bild 1 von 3 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: Schritt 1, Bild 2 von 3 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: Schritt 1, Bild 3 von 3
    • Flip the vacuum so the bottom base is visible.
    • Gently pry the bottom two wheels off with a plastic opening tool.
  2. Shark Rocket HV301 Rotary Belt Replacement: Schritt 2, Bild 1 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 2, Bild 2 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 2, Bild 3 von 3
    • Remove five visible screws with a Phillips #2 screwdriver.
    • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
  3. Shark Rocket HV301 Rotary Belt Replacement: Schritt 3, Bild 1 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 3, Bild 2 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 3, Bild 3 von 3
    • Remove plate covering the roller brush.
  4. Shark Rocket HV301 Rotary Belt Replacement: Schritt 4, Bild 1 von 2 Shark Rocket HV301 Rotary Belt Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
  5. Shark Rocket HV301 Rotary Belt Replacement: Schritt 5, Bild 1 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 5, Bild 2 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 5, Bild 3 von 3
    • Turn the vacuum over so the rotary brush is on the ground.
    • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
  6. Shark Rocket HV301 Rotary Belt Replacement: Schritt 6, Bild 1 von 2 Shark Rocket HV301 Rotary Belt Replacement: Schritt 6, Bild 2 von 2
    • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
    • Proceed with removing the upper casing.
  7. Shark Rocket HV301 Rotary Belt Replacement: Schritt 7, Bild 1 von 2 Shark Rocket HV301 Rotary Belt Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
  8. Shark Rocket HV301 Rotary Belt Replacement: Schritt 8, Bild 1 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 8, Bild 2 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 8, Bild 3 von 3
    • Remove the rotary belt on right side of vacuum from the bearing.
    • Gently lift the casing to remove the belt and brush from the vacuum.
  9. Shark Rocket HV301 Rotary Belt Replacement: Schritt 9, Bild 1 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 9, Bild 2 von 3 Shark Rocket HV301 Rotary Belt Replacement: Schritt 9, Bild 3 von 3
    • Gently pry off the plastic casing on both sides of rotary brush.
    • Lift the clear plastic shell from the rotary brush.
  10. Shark Rocket HV301 Rotary Belt Replacement: Schritt 10, Bild 1 von 1
    • Remove the rotary belt attached to the brush and replace it if needed.
  11. Shark Rocket HV301 Rotary Belt Replacement, Rotary Belt: Schritt 11, Bild 1 von 1
    • Replace belt if torn or damaged.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-5, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G5
4 Mitglieder
14 Anleitungen geschrieben
3 Kommentare
Where can I find the rotary belt for the Shark Duo?
oneupchallenges - Antwort
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Jennifer Dalton - Antwort
Thanks for the guide it came in super handy
SYSTEM 855 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 32
Letzte 30 Tage: 186
Insgesamt: 33,348
