Zum Hauptinhalt wechseln
Shark Rocket Powerhead AH401 Motherboard Replacement
Was du brauchst
  1. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: Schritt 1, Bild 1 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: Schritt 1, Bild 2 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: Schritt 1, Bild 3 von 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 2, Bild 1 von 2 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: Schritt 3, Bild 1 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: Schritt 3, Bild 2 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: Schritt 3, Bild 3 von 3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 4, Bild 1 von 2 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: Schritt 5, Bild 1 von 2 Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: Schritt 5, Bild 2 von 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  6. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver.
    • Remove the airpath grille by gently lifting up and away from the motor compartment.
  7. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 8, Bild 1 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 8, Bild 2 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Lift and gently remove the hinge compartment covering the motherboard.
  9. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
  10. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 10, Bild 1 von 2 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Lift the motherboard out of its compartment.
  11. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 11, Bild 1 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 11, Bild 2 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Locate and remove these connections by pulling the plugs out of the sockets.
  12. Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 12, Bild 1 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 12, Bild 2 von 3 Shark Rocket Powerhead AH401 Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Flip the motherboard over to reveal the wires underneath.
    • Locate and cut all the wires connected to the motherboard using cutting pliers.
Abschluss
Cal Poly, Team S19-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 502
