Zum Hauptinhalt wechseln
Shark Rocket Powerhead AH401 Panel Screws Replacement
Was du brauchst
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: Schritt 1, Bild 1 von 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: Schritt 1, Bild 2 von 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: Schritt 1, Bild 3 von 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: Schritt 2, Bild 1 von 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: Schritt 2, Bild 2 von 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: Schritt 3, Bild 1 von 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: Schritt 3, Bild 2 von 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: Schritt 3, Bild 3 von 3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: Schritt 4, Bild 1 von 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: Schritt 4, Bild 2 von 2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: Schritt 5, Bild 1 von 2 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: Schritt 5, Bild 2 von 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Abschluss
Toan Pham
269 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S19-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 967
