Einleitung
Does your vacuum fail to pick up particles on your floor? If so, this guide outlines how to remove the two vacuum tubes on the Shark Rocket Professional. While reading this guide, you will also learn how to unclog your vacuum to improve suction.
Was du brauchst
Look at the Shark Rocket Professional's Extension Rod.
Identify where the hose connects to the main body of the vacuum.
Press the tabs on the sides of the connector to remove the hose.
Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
Press the button and remove the handle.
Look at the vacuum handle.
Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
Look a your handle.
Using your hands, pull the tube from the nozzle of the handle.
The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
How do you replace the hose in the beater head
daveve2 -
Thank you for this, this guide helped a ton.
