Zum Hauptinhalt wechseln
Shark Rocket Professional Hose Replacement
Was du brauchst
  1. Shark Rocket Professional Hose Replacement, Main Hose: Schritt 1, Bild 1 von 3 Shark Rocket Professional Hose Replacement, Main Hose: Schritt 1, Bild 2 von 3 Shark Rocket Professional Hose Replacement, Main Hose: Schritt 1, Bild 3 von 3
    • Look at the Shark Rocket Professional's Extension Rod.
    • Identify where the hose connects to the main body of the vacuum.
    • Press the tabs on the sides of the connector to remove the hose.
    • You can use a long, thin object to unclog the hose.
    • If this fixes your problem, then you are finished with this guide.
  2. Shark Rocket Professional Hose Replacement: Schritt 2, Bild 1 von 2 Shark Rocket Professional Hose Replacement: Schritt 2, Bild 2 von 2
    • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
    • Press the button and remove the handle.
  3. Shark Rocket Professional Hose Replacement: Schritt 3, Bild 1 von 2 Shark Rocket Professional Hose Replacement: Schritt 3, Bild 2 von 2
    • Look at the vacuum handle.
    • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
  4. Shark Rocket Professional Hose Replacement: Schritt 4, Bild 1 von 3 Shark Rocket Professional Hose Replacement: Schritt 4, Bild 2 von 3 Shark Rocket Professional Hose Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to pry open the handle.
    • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
    • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
  5. Shark Rocket Professional Hose Replacement: Schritt 5, Bild 1 von 3 Shark Rocket Professional Hose Replacement: Schritt 5, Bild 2 von 3 Shark Rocket Professional Hose Replacement: Schritt 5, Bild 3 von 3
    • The orange plastic piece may have naturally fallen out at this point.
    • Look a your handle.
    • Using your hands, pull the tube from the nozzle of the handle.
    • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
    • Cut this connection with wire clippers to remove and replace your tube.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brad Iglesia
316 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G6, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - Antwort
How do you replace the hose in the beater head
daveve2 -
Thank you for this, this guide helped a ton.
Bradlee Johnson - Antwort
How long does it take to answer acquestion?
daveve2 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 5,881
