Einleitung
Before completing this guide, it's important to know how to remove the dust cap. If you are unsure how to do so, the dust cap guide is shown below to help you out.
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. First, locate the  button that says "Dust Cup".  It is right next to the power button at the base of the handle.
    • First, locate the button that says "Dust Cup". It is right next to the power button at the base of the handle.
    • Press the button down completely; you should feel a click.
  2. Grab the handle of the  dust cup, then pull up and away from the vacuum.
    • Grab the handle of the dust cup, then pull up and away from the vacuum.
    • You must press the button and pull the dust cap simultaneously at first to release the latch.
    • As you look beneath the base of the dust cup, you will see a white foam filter. Remove this filter with your fingers.
    • Removing the first filter will reveal a second, thicker foam filter. Remove this as well.
    • Shark recommends that you rinse and air dry these filters monthly.
    • Remember to replace the filters in the correct order.
    • A dust filter is located within the dust cup. To access it, open the dust cup by pressing the orange tab on the front and pulling up on the handle.
    • Find the cylindrical screen in the center of the dust cap, grab the top, and pull it straight out.
    • If this filter is dirty, shake it or rinse it off to clean it.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Theo Watkins
Mitglied seit 23.01.2018
326 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G6, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 80
Insgesamt: 440
