Zum Hauptinhalt wechseln
Shark Rocket Zero-M Belt Replacement
Was du brauchst
  1. Shark Rocket Zero-M Belt Replacement, Belt: Schritt 1, Bild 1 von 1
    • Flip the vacuum on its right side.
  2. Shark Rocket Zero-M Belt Replacement: Schritt 2, Bild 1 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 2, Bild 2 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 2, Bild 3 von 3
    • Turn the T10 Security Bit screwdriver counterclockwise to remove the 15mm screw.
  3. Shark Rocket Zero-M Belt Replacement: Schritt 3, Bild 1 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 3, Bild 2 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 3, Bild 3 von 3
    • Turn the vacuum face down.
  4. Shark Rocket Zero-M Belt Replacement: Schritt 4, Bild 1 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 4, Bild 2 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to pry the side of the vacuum open.
  5. Shark Rocket Zero-M Belt Replacement: Schritt 5, Bild 1 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 5, Bild 2 von 3 Shark Rocket Zero-M Belt Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to pry the old belt away from the two gears.
    • The new belt will be tight and difficult to put back on. In order to reinstall, place the belt on the brushroll, then rotate the brushroll a couple rotations to make sure the belt is aligned correctly.
  6. Shark Rocket Zero-M Belt Replacement: Schritt 6, Bild 1 von 1
    • Repeat on the other side of the vacuum.
Abschluss
Nadia Martinez
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S1-G4, Harris Spring 2021 Mitglied von CSU Los Angeles, Team S1-G4, Harris Spring 2021
CSULA-HARRIS-S21S1G4
1 Mitglied
Ein Kommentar
What is the belt part number looking but can not fine.
Help would be greatly appreciated thank you
jason kennedy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 34
Insgesamt: 3,370
