Einleitung
The brushroll motor is what powers the brushroll and makes it spin. If the brushroll is spinning, the motor may need to be replaced.
Was du brauchst
Locate the release button at the top of the vacuum pod next to the handle.
Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
Remove the panel to reveal the motor screw.
Remove the 7.5mm Torx #20 motor screw.
Remove the motor.
