Einleitung
Steps 1-3 provide instructions on how to remove the post-motor (HEPA) filter. Step 4 provides instructions on how to remove the pre-motor foam & felt filters. Shark recommends you hand rinse the post-motor (HEPA) filter once a year. The manufacturer also recommends you hand wash the pre-motor filters with soap once every three months.
Lay the vacuum pod flat with the bottom facing towards you.
Pull the silver release latch and lift away from the body of the vacuum from the bottom.
Rest the vacuum pod upright.
Press down on the buttons on either side of the handle labeled “dust cup release.”
Lift the dust cup away from from the body of the vacuum to uncover the foam filter.
Lift the foam filter and filter frame out of the center of the vacuum to unveil the felt filter.
Remove the felt filter by lifting the pull-tab.
3 Kommentare
I cleaned all filters vacuum a rug and then went to regular floors and the vacuum stopped all together I don't know what it is belt looks new
It just stopped running
I cleaned all filters let them dry then replaced to vacuum started vacuum and it ran less than 5minutes and it shut down
