Einleitung
The vacuum comes with several hose attachments and pathways through which debris passes through. To clean or remove blockages from hose attachments, it may be necessary to remove the hose and wand attachments.
Place the vacuum upright and locate the attachment you want removed.
Slide the attachments off of the end of the wand.
Some attachments may have a "Release" button--if so, hold down the button while sliding the attachment off.
Locate the button that says “Release Wand” and press down.
Press button while lifting upwards on the handle at the top of the wand.
Locate the black hose on the back of the vacuum.
Locate the silver release levers on the top and bottom of the hose.
Press on the silver release levers and pull up and away from the device to release the hose.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
I cannot figure out how to attach het attachments for my new Shark Rotary 752. They just will not go in.
I have a shark duoclean Hv3900k and have attached the dusting accessory but I can't get it off after hoovering my staircase
A small white plastic ring which attaches the hose to the junction of the rotating part of machine. the model is NV50101, Shark Rotator Professional. Since I can't keep the hose connected to the vacuum, it cannot be used.
The small white plastic ring on the bottom of the hose is broken and thus the hose will not lock into place.
