Zum Hauptinhalt wechseln
Shark Rotator NV502 Roller Brush Replacement
Was du brauchst
  1. Shark Rotator NV502 Roller Brush Replacement, Roller Brush: Schritt 1, Bild 1 von 2 Shark Rotator NV502 Roller Brush Replacement, Roller Brush: Schritt 1, Bild 2 von 2
    • Pull the handle while pressing the lift away button to remove the body of the vacuum.
  2. Shark Rotator NV502 Roller Brush Replacement: Schritt 2, Bild 1 von 2 Shark Rotator NV502 Roller Brush Replacement: Schritt 2, Bild 2 von 2
    • Flip the base of the vacuum over to access the bottom.
    • Remove the two small wheels with a metal spudger.
  3. Shark Rotator NV502 Roller Brush Replacement: Schritt 3, Bild 1 von 2 Shark Rotator NV502 Roller Brush Replacement: Schritt 3, Bild 2 von 2
    • Remove the nine 16 mm screws using the Phillips #2 Screwdriver. Press on the side tabs in the middle of the panel and pull up to reveal the screw under the hose connection.
    • Remove the two 13.5 mm screws using the Phillips #2 Screwdriver.
  4. Shark Rotator NV502 Roller Brush Replacement: Schritt 4, Bild 1 von 2 Shark Rotator NV502 Roller Brush Replacement: Schritt 4, Bild 2 von 2
    • Pull up on the cover and move it to the side.
    • Remove the wire attached to the base by squeezing the pin and pulling up.
  5. Shark Rotator NV502 Roller Brush Replacement: Schritt 5, Bild 1 von 2 Shark Rotator NV502 Roller Brush Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 11 mm screws using the Phillips #2 screwdriver.
    • Lift the roller brush cover up.
  6. Shark Rotator NV502 Roller Brush Replacement: Schritt 6, Bild 1 von 1
    • Pull out the roller brush.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Samuel
307 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-3, Livingston Fall 2016 Mitglied von Cal Poly, Team 4-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G3
4 Mitglieder
19 Anleitungen geschrieben
6 Kommentare
Good day, I have a rotator lift away NV500 my belt indicator light stopped working but I was still getting suction. I replaced the filters and hep filters,as well as changed the belt. I cleaned off the dust and then carefully put the vacuum back to gather. I went to plug it in all worked until I pushed the roller brush indicator on and it still did not work. What else could it be? Any suggestions.
I await your reply
Angela
Angela Cox - Antwort
I have the same issue…brush roller will not work.
csweetccr - Antwort
Same here what would be wrong with it
Johnnie Twyman -
Great instructions - the 11mm hidden screws plus one more were tricky to find. Thanks so much for the great graphics and very clear disassembly steps; I almost gave up and was going to take it to a dealer for a costly repair fee. Thanks again!
Mathew Curran - Antwort
Great directions and guidance - many thanks!
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 40
Letzte 30 Tage: 199
Insgesamt: 26,070
