Einleitung
The roller brush can have debris that will cause the vacuum to not work properly. It is important that you always clean your roller brush after every use, so that your Shark Rotator Powered Lift Away Speed Vacuum can perform at it's best. This guide will show you how to change your roller brush if it becomes damaged or is broken.
Was du brauchst
Turn the vacuum on its side.
Using a quarter, twist the three green locks to the unlock position.
Pull the bottom roller brush cover to open the vacuum.
Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
Remove the single 13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
Turn the vacuum around.
Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
Remove the grey panel from the opposite side, by uncrewing the single 13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
13 Kommentare
Exactly, I struggled for sometime trying to find that 1 little screw that was a Phillips head.
I figured out how to get it apart… Where do I find a new roller?
where can i get a new roller also...
