Einleitung
This guide will show you how to replace the HEPA filter which is responsible for trapping small particles that can be easily recirculated into the air. When the HEPA Filter is extremely dirty, you may want to consider replacing it.
Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
Remove the red cover from the front of the vacuum by pulling the latch found at the bottom of the cover forward and moving the whole cover downward.
Remove the filter by pulling it straight out.
To clean the filter, rinse it under water and allow it to dry before placing it back in the vacuum.
