Zum Hauptinhalt wechseln
Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: Schritt 1, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: Schritt 1, Bild 2 von 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: Schritt 2, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: Schritt 2, Bild 2 von 2
    • Remove the red cover from the front of the vacuum by pulling the latch found at the bottom of the cover forward and moving the whole cover downward.
  3. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: Schritt 3, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: Schritt 3, Bild 2 von 2
    • Remove the filter by pulling it straight out.
    • To clean the filter, rinse it under water and allow it to dry before placing it back in the vacuum.
Abschluss
Cal Poly, Team S19-G3, White Winter 2019 Mitglied von Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 375
