Einleitung
When the vacuum is not turning on or providing no suction, this may indicate that the motor needs replacement.
Was du brauchst
Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
Take off white plastic cover exposing the motor in its insulation.
Remove the motor from the base and slide the insulation down along the wires.
Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
