Zum Hauptinhalt wechseln
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
Was du brauchst
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: Schritt 1, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: Schritt 1, Bild 2 von 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 2, Bild 1 von 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 2, Bild 2 von 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 3, Bild 1 von 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 3, Bild 2 von 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 3, Bild 3 von 3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 4, Bild 1 von 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 4, Bild 2 von 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: Schritt 4, Bild 3 von 3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S19-G3, White Winter 2019 Mitglied von Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
What is the motor PN and where can I get one?
Dennis Meece - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 1,477
