Zum Hauptinhalt wechseln
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement
Was du brauchst
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: Schritt 1, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: Schritt 1, Bild 2 von 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 2, Bild 1 von 1
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 3, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 3, Bild 2 von 2
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 4, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 4, Bild 2 von 2
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 5, Bild 1 von 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 5, Bild 2 von 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 5, Bild 3 von 3
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 6, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 6, Bild 2 von 2
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 7, Bild 1 von 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 7, Bild 2 von 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 7, Bild 3 von 3
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 8, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 8, Bild 2 von 2
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 9, Bild 1 von 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 9, Bild 2 von 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 9, Bild 3 von 3
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 10, Bild 1 von 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: Schritt 10, Bild 2 von 2
    • Wiggle the brush roller upwards from the left and right side slots.
Abschluss
Daniel Ceja
277 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S19-G3, White Winter 2019 Mitglied von Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 982
