Zum Hauptinhalt wechseln
Shark Steam Pocket Mop Ejection Button Assembly Replacement
Was du brauchst
  1. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: Schritt 1, Bild 2 von 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: Schritt 2, Bild 1 von 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: Schritt 2, Bild 2 von 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: Schritt 2, Bild 3 von 3
    • Begin by removing the two quarter inch Phillips head screws you see pictured. These screws hold the bottom part of the button assembly to the Mop's midframe.
    • Be very careful not to lose the spring that is in between the top and bottom part of the button assembly.
  3. Shark Steam Pocket Mop Ejection Button Assembly Replacement: Schritt 3, Bild 1 von 2 Shark Steam Pocket Mop Ejection Button Assembly Replacement: Schritt 3, Bild 2 von 2
    • Once the bottom piece of the assembly has been removed, carefully turn the mop over and move the front panel of the mop to the side
    • Once you've turned your device over you should be able to remove the top portion of the button assembly with ease. It should not require anything more than your fingers.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jacob Howe
549 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S13-G7, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 300
