Zum Hauptinhalt wechseln
Shark Steam Pocket Mop Steam Head Hose Replacement
Was du brauchst
  1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: Schritt 1, Bild 1 von 3 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: Schritt 1, Bild 2 von 3 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: Schritt 1, Bild 3 von 3
    • Start by removing this quarter inch Phillips head screw
    • Next remove the two 1/8th inch Phillips head screws at the bottom of the connector piece.
    • Next remove the nine 1/8th inch Phillips head screws along the base of the steam head connection.
    • Next remove the two 1/8th inch Phillips head screws along the base of the steam head connector.
  2. Shark Steam Pocket Mop Steam Head Hose Replacement: Schritt 2, Bild 1 von 3 Shark Steam Pocket Mop Steam Head Hose Replacement: Schritt 2, Bild 2 von 3 Shark Steam Pocket Mop Steam Head Hose Replacement: Schritt 2, Bild 3 von 3
    • Once all the screws are removed and the baseplate of the steam head connection has been placed aside, gently remove the connector from the bottom of the base.
    • Gently remove the end caps of the hinge piece of the connector piece with your fingers.
    • Gently remove the host connection from the back plate.
  3. Shark Steam Pocket Mop Steam Head Hose Replacement: Schritt 3, Bild 1 von 2 Shark Steam Pocket Mop Steam Head Hose Replacement: Schritt 3, Bild 2 von 2
    • Use your tweezers to remove the metal ring holding the hose to the plastic end piece and replace the hose / bit as needed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jacob Howe
549 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S13-G7, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Ok, but where do I get a replacement hose?
semajrolyat - Antwort
Same question as semajrolyat: where to source replacement hose?
CLIFTON CHANG - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,937
