Zum Hauptinhalt wechseln
Shark Steam Pocket Mop Water Tank / Bladder Replacement
Was du brauchst
  1. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: Schritt 1, Bild 1 von 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: Schritt 1, Bild 2 von 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: Schritt 2, Bild 1 von 2 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: Schritt 2, Bild 2 von 2
    • Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
  3. Shark Steam Pocket Mop Water Tank / Bladder Replacement: Schritt 3, Bild 1 von 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement: Schritt 3, Bild 2 von 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement: Schritt 3, Bild 3 von 3
    • Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder.
    • Then gently lift the water tank / bladder out of its plastic housing. and turn it over.
    • To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
Abschluss
Jacob Howe
549 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S13-G7, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 635
