Zum Hauptinhalt wechseln
Shark Ultimate Professional Circuit Board Replacement
Was du brauchst
  1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: Schritt 1, Bild 1 von 3 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: Schritt 1, Bild 2 von 3 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: Schritt 1, Bild 3 von 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
    Frag FixBot
    Kommentar hinzufügen
  2. Shark Ultimate Professional Circuit Board Replacement: Schritt 2, Bild 1 von 2 Shark Ultimate Professional Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
    Frag FixBot
  3. Shark Ultimate Professional Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Pull the split end of the power cord upward through the ball joint.
    • Set aside the power cord.
    Frag FixBot
  4. Shark Ultimate Professional Circuit Board Replacement: Schritt 4, Bild 1 von 3 Shark Ultimate Professional Circuit Board Replacement: Schritt 4, Bild 2 von 3 Shark Ultimate Professional Circuit Board Replacement: Schritt 4, Bild 3 von 3
    • Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
    • Remove from left to right
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
    Frag FixBot
  5. Shark Ultimate Professional Circuit Board Replacement: Schritt 5, Bild 1 von 2 Shark Ultimate Professional Circuit Board Replacement: Schritt 5, Bild 2 von 2
    • Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
    Frag FixBot
  6. Shark Ultimate Professional Circuit Board Replacement: Schritt 6, Bild 1 von 2 Shark Ultimate Professional Circuit Board Replacement: Schritt 6, Bild 2 von 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Gently pull the circuit board from affixed position.
    • The circuit board will not be completely separated at this point.
    Frag FixBot
  7. Shark Ultimate Professional Circuit Board Replacement: Schritt 7, Bild 1 von 3 Shark Ultimate Professional Circuit Board Replacement: Schritt 7, Bild 2 von 3 Shark Ultimate Professional Circuit Board Replacement: Schritt 7, Bild 3 von 3
    • Remove the mode display piece and set aside.
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    Frag FixBot
  8. Shark Ultimate Professional Circuit Board Replacement: Schritt 8, Bild 1 von 1
    • Remove the connecting wire from the connected adapter in the handle by pulling lightly.
    • Set aside the circuit board.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
My shark 1505C does not have philips screws on the back. They are security torx and I cannot find a tool to open it.
Where can I buy a main board for this iron ?
Thanks
NevG.
nevstarg - Antwort Teilen
where do I buy it's circuit board?
egovieira - Antwort Teilen
Where can u buy the circuit board professional 1800 version?
Astinder Singhera - Antwort Teilen
How much does the circuit board cost? and where can i purchase it?
D.A. Willis - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 18
Letzte 30 Tage: 121
Insgesamt: 4,485
