Zum Hauptinhalt wechseln
Shark Ultimate Professional Mode Display Replacement
Was du brauchst
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: Schritt 1, Bild 1 von 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: Schritt 1, Bild 2 von 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: Schritt 1, Bild 3 von 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
    Frag FixBot
    Kommentar hinzufügen
  2. Shark Ultimate Professional Mode Display Replacement: Schritt 2, Bild 1 von 2 Shark Ultimate Professional Mode Display Replacement: Schritt 2, Bild 2 von 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
    Frag FixBot
  3. Shark Ultimate Professional Mode Display Replacement: Schritt 3, Bild 1 von 3 Shark Ultimate Professional Mode Display Replacement: Schritt 3, Bild 2 von 3 Shark Ultimate Professional Mode Display Replacement: Schritt 3, Bild 3 von 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
    Frag FixBot
  4. Shark Ultimate Professional Mode Display Replacement: Schritt 4, Bild 1 von 3 Shark Ultimate Professional Mode Display Replacement: Schritt 4, Bild 2 von 3 Shark Ultimate Professional Mode Display Replacement: Schritt 4, Bild 3 von 3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
    Frag FixBot
  5. Shark Ultimate Professional Mode Display Replacement: Schritt 5, Bild 1 von 2 Shark Ultimate Professional Mode Display Replacement: Schritt 5, Bild 2 von 2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
    Frag FixBot
  6. Shark Ultimate Professional Mode Display Replacement: Schritt 6, Bild 1 von 2 Shark Ultimate Professional Mode Display Replacement: Schritt 6, Bild 2 von 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
    Frag FixBot
  7. Shark Ultimate Professional Mode Display Replacement: Schritt 7, Bild 1 von 3 Shark Ultimate Professional Mode Display Replacement: Schritt 7, Bild 2 von 3 Shark Ultimate Professional Mode Display Replacement: Schritt 7, Bild 3 von 3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 1,084
