Zum Hauptinhalt wechseln
Shark Ultimate Professional Reservoir Replacement
Was du brauchst
  1. Shark Ultimate Professional Reservoir  Replacement, Reservoir: Schritt 1, Bild 1 von 3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: Schritt 1, Bild 2 von 3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: Schritt 1, Bild 3 von 3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
    Frag FixBot
    Kommentar hinzufügen
  2. Shark Ultimate Professional Reservoir  Replacement: Schritt 2, Bild 1 von 2 Shark Ultimate Professional Reservoir  Replacement: Schritt 2, Bild 2 von 2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
    Frag FixBot
  3. Shark Ultimate Professional Reservoir  Replacement: Schritt 3, Bild 1 von 1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
    Frag FixBot
  4. Shark Ultimate Professional Reservoir  Replacement: Schritt 4, Bild 1 von 3 Shark Ultimate Professional Reservoir  Replacement: Schritt 4, Bild 2 von 3 Shark Ultimate Professional Reservoir  Replacement: Schritt 4, Bild 3 von 3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    Frag FixBot
  5. Shark Ultimate Professional Reservoir  Replacement: Schritt 5, Bild 1 von 2 Shark Ultimate Professional Reservoir  Replacement: Schritt 5, Bild 2 von 2
    • Remove two screws (left and right) affixed to circuit board.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
i am trying to replace the thermal cutoff but can’s remember the wire inside how to replace
primrose33166 - Antwort Teilen
I have a constant leak in the vertical position - long after the iron is cold. The repair presented is well done. However it stopped short and doesn't get to the reservoir - thanks
Dalmacca - Antwort Teilen
Then WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT?
Muhammad Ahmad - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 69
Insgesamt: 3,022
